• 398 views | 3 messages Discussion: LEAP
    Topic: Error reading optimization results Subscribe | Previous | Next
  • Robert Istrate 2/7/2018
    Hi guys,
    I have some problems with LEAP2018 when I try to run the optimization results of the Optimization Excercise. I haven't change anything of the original excercise file. I tried to create a new area too, but the result is the same. Could anybody help me with it?
    Thank you,
    Robert
  • Emily Ghosh 2/7/2018
    Hi Robert,
    Thank you for notifying us of the problem. We were able to replicate the error in the 64-bit version of LEAP 2018 and are working towards finding a solution to fix this issue.
    If you are just working on the training exercises, I suggest downloading and using the 32-bit version of LEAP for now, and I will let you know once the issue in the 64-bit version is resolved. The 32-bit version can be downloaded here: https://www.energycommunity.org/default.asp?action=download.
  • Robert Istrate 2/8/2018
    Hi Emily,
    Thanks for your recommendation. Finally I achieved run the model with 32 bit version.
    Robert.
