• 609 views | 4 messages Discussion: LEAP
    Topic: How to open older version of LEAP Model ? Subscribe | Previous | Next
  • Nur Arief 3/19/2018
    I have an old LEAP model from 2011th, that I need to look for my reference in my new leap model.
    Is it
    possible to open older version of LEAP model in this new version of LEAP software and renew it?
    Thanks a lot.
    Arief
  • Emily Ghosh 3/19/2018
    Hi Arief,
    As long as the model is saved as a .leap file, there should not be any issue with using it in the newest version of LEAP. After you open the file by going to Area --> Install --> Install from File, LEAP will automatically run a routine to detect and fix any conflicts with the newest version of LEAP.
  • Nur Arief 3/25/2018
    Hi Emily,
    There is some error when i try to open the old model .leap file area.
    Arief
  • Taylor Binnington 3/29/2018
    Hi Nur - try right-clicking on the leap.exe executable (you should find this as a shortcut in your Start menu), and selecting "Run as Administrator". Once the software starts, then perform the steps above that Emily has laid out.
    Good luck,
