232 views | 2 messages
Hiding branches / results for one branch only
Stephane de la Rue du Can 3/22/2018
Hi
Is it possible to calculate results for one sector only?
Is there a way to quickly "hide" all the branches that you don't want to calculate?
Thank you
Stephane
Emily Ghosh 3/22/2018
Hi Stephane,
When you click on the blue tree icon in the Tree toolbar (see screenshot attached), it will open up the "Select Visible Branches" dialog box where you can select which branches are hidden in the analysis.
