• 448 views | 3 messages Discussion: LEAP
    Topic: Decimal separator Subscribe | Previous | Next
  • Biljana Cherepnalkoska 4/18/2018
    I need advice how can I change decimal separator in the LEAP software from ',' into '.'. As I input decimal data in the software, they are separated with ','.
    Can you please give me directions?
    Thank you in advance.
    Biljana
  • Emily Ghosh 4/18/2018
    Hi Biljana,
    To change the decimal separator:
    • Open Control Panel (if you are using Windows 10, click on Settings from the Start Menu, and search for "Control Panel")
    • Select Clock, Language, and Region
    • In the Formats tab, click on Additional Settings
    • Change the decimal settings to "." and the list separator to ","
    • Apply the settings and restart LEAP
  • Biljana Cherepnalkoska 4/19/2018
    Hi Emily,
    Thank you a lot, now it is OK.
    All the best,
    Biljana
