• 304 views | 2 messages Discussion: LEAP
    Topic: Run two versions Subscribe | Previous | Next
  • Felix Salazar 4/27/2018
    Good afternoon,
    I would like how I could run simultaneously on the same LEAP computer version 2018 and version 2012. A friend can work with both versions. I need to verify the compatibility of a file that does not give me the same results after updating.
    Thanks in advance for the support.
    Félix Salazar
  • Emily Ghosh 5/4/2018
    Hi Felix,
    There have been many changes to LEAP since the 2012 version, including bug fixes, which may be why the results are slightly different. We also do not provide technical support for previous versions of LEAP, but if you are having problems with the latest version of LEAP, please provide a detailed description of the problem you are experiencing and a copy of your .LEAP file to leap@sei.org, and we'd be happy to look into it.
