• 317 views | 2 messages Discussion: LEAP
    Topic: "Production" module in results Subscribe | Previous | Next
  • Felix Salazar 4/29/2018
    Greetings community,
    I have a question about "Production" in the case I am working. Basically I have in my primary sources: NG CA, NG Lic and NG EyP; in secondary sources Metano Imp. Col. However, as seen in the Sankey diagram, the "Production" or "Transformation" modules were not seen.
    In the primary sources we have Natural Gas for which values ​​are indicated in the variables: "Base year reserves" and "Local cost"; for the secondary ones, which refers to imported gas already processed (methane), the variables "Imported resources" and "Import costs" were taken into account.
    Is it necessary to declare another variable to take into account the primary resources? What would it be? On the other hand, in the "Processing" module of "Transformation", only the default "proportion of the input source" is taken as variable.
    Next, I leave attached images in which the tree diagram, health diagram and the results table for the year 2009 are shown.
    Grateful in advance,
    Felix
    Attachments:  Consulta a LEAP_2.pdf [4]
  • Taylor Binnington 5/7/2018
    Hi Felix,
    It's not obvious what's happened without seeing your model in more detail. Would you mind attaching it to this thread?
