• 840 views | 6 messages Discussion: LEAP
    Topic: In active result Subscribe | Previous | Next
  • Chhay Lyheang 5/7/2018
    When i push the result, it appeared like the filed in attached. I used LEAP model in order to analyze the CO2 emission from power sector. Please kindly explain me about that problem.
    Sincerely,
    Lyheang
  • Emily Ghosh 5/7/2018
    Hi Chhay,
    Sorry for the troubles you are having. Have you tried restarting LEAP? Sometimes this fixes the problem.
    Also, I noticed that you are using the 64-bit version of LEAP which was only recently released this year. Unless you plan on developing a very large model, we recommend that you install and use the 32-bit version for now since it is slightly faster and thoroughly road-tested. You can download the 32-bit version through the LEAP downloads page: https://www.energycommunity.org/default.asp?action=download
    Should you continue to have problems after installing the 32-bit version of LEAP, please let us know.
    Thanks deeply for your fast responding. I will follow what you mention.
    After i installed 32 bit, it still does not working. Does it error because of the wrong input data?
  • Emily Ghosh 5/8/2018
    Hi Chhay,
    It is not immediately apparent why this may be happening. Do you mind emailing a copy of your .LEAP backup file to leap@sei.org? I can take a look to figure out the issue. To create the backup file, go to Area --> Backup.
  • Chhay Lyheang 5/10/2018
    I recently solve that problem.
    Deeply thanks for your helping.
    I will ask you again if i have question.
    Lyheang,
