Hi Moustafa,
You can use the
ScenarioValue function to reference the value from another
 scenario within the same region and the
RegionValue function to reference the value from another region within the same scenario.
While there isn't a built-in LEAP function to reference
another region in
another scenario (Any Region/Reference Scenario), there is an indirect way to do this through the creation of a
User-Variable. For example, you could create a User-Variable, and then in each region, enter an expression which references a value in another scenario through the
ScenarioValue function. Then, in your coal demand expression, you could reference this new User-Variable using the
RegionValue function.
To give you a better idea of what I mean, here are example expressions for the user-variable and coal demand in the Mitigation scenario. This example assumes that your coal demands are entered in the Total Energy variable:
- User Variable expression in Mitigation Scenario in Region X: ScenarioValue(Demand\Electricity:Total Energy[MWh],Baseline)
- Total Energy Demand expression in Mitigation Scenario in World (based on the formula you provided in your post): ScenarioValue(Baseline) - RegionValue(Demand\Electricity:UserVariable[MWh],Region X) + RegionValue(Demand\Electricity:Total Energy[MWh],Region X)
