• 302 views | 2 messages Discussion: LEAP
    Topic: Adding Scenarios in the LEAP model Subscribe | Previous | Next
  • Ahmed Faizan 5/28/2018
    I'm trying to complete the Exercise 1 from LEAP Manual and halfway through it.
    I'm at a stage where i need to add different scenarios for Urban and Rural Sectors under Key Assumption Branch. I have added them according to my best understand, however, they do not reflect in the result. I'm mapping the data from 2010 to 2040.
    Would appreciate any help. Thank you
    Ahmed
  • Emily Ghosh 6/4/2018
    Hi Ahmed,
    Sorry for the delay in responding. Currently you have the Urban and Rural branches under the Key Assumptions branch, however they should be under the Demand branch. Refer to the diagram on Page 7 of the training materials which gives you a clue in how the branch structure should look like.
    If you are really stuck, note that you can view completed versions of each exercise by opening the Freedonia dataset built into LEAP. This will allow you to compare your progress against the finished product. To do this, first save your own working model and then go to Area --> Open --> Freedonia to open the completed Freedonia dataset. Then, select Area --> Revert to Version to view the results of the exercise you are working on.
