• 257 views | 2 messages Discussion: LEAP
    Topic: Environmental Loadings tab missing Subscribe | Previous | Next
  • Døgg Durhuus 6/1/2018
    Hi
    Hope someone here might be able to help. I'm currently working on the exercises and have reached section 1.5: Emissions. All my results so far match the results obtained in the provided example (Freedonia).
    However, I can not find the TED button anywhere. As I understand it, I have to check the box "Energy Sector Effect Loadings" in "Basic Parameters" and I have done this. Then I believe I should be able to find an "Environmental Loadings"-tab, but it is nowhere to be found. I have looked in every section of the tree.
    (If I instead check the box "Costs", in "Basic Parameters", a Cost-tab appears. If I go into the Freedonia example, I can see an "Avg Environmental Loading"-tab, but still no TED button.)
    What am I missing? All help would be very much appreciated.
    Have a great day,
    Døgg
  • Emily Ghosh 6/4/2018
    Hi Døgg,
    Sorry for the confusion. The process for adding environmental loadings changed in LEAP version 2018 and hasn't been reflected in the training materials. Please refer to the attached post for the new process of adding environmental loadings:
