• 369 views | 2 messages Discussion: LEAP
    Topic: Error Opening Results View Subscribe | Previous | Next
  • Arwa Jaradat 5/29/2018
    Hi
    I have a problem with the software. something happens and I cant get any results when I run the result icon.
    what happen and how I can fix it.?
    regards
    Arwa Jaradat
  • Emily Ghosh 6/4/2018
    Hi Arwa,
    Sorry for the trouble you are having. Are you still having a problem accessing the results? If so, which version of LEAP are you using? We have noticed this issue occur in the 64-bit version which was only released this year. Unless you are developing a very large model, I recommend using the 32-bit version of LEAP for now since it is slightly faster and thoroughly road-tested. You can
    download the 32-bit version through the LEAP downloads page here: https://www.energycommunity.org/default.asp?action=download
