• 400 views | 3 messages Discussion: LEAP
    Topic: Script menu Subscribe | Previous | Next
  • Rahmat Al hasibi 6/4/2018
    Dear All,
    In the newest version of LEAP, I cannot find script menu. This menu usually in the advance menu. Is the menu already moved somewhere else or there is anything I missed in the modelling process?
    Thank you very much.
  • Emily Ghosh 6/6/2018
    Hi Rahman,
    If you are not seeing the Advanced menu, it is likely because you are using the 64-bit version of LEAP and a special scripting control has failed to register. If so, you have a few options:
    1. Use the 32-bit version of LEAP instead,
    2. Uninstall and reinstall of the latest 64-bit version, or
    3. Manually install the script (instructions for this are provided in the last post on this thread: https://www.energycommunity.org/default.asp?action=9&tid=3984&fid=22)
  • Reza Ramadhan 4/10/2021
    is 32-bit better than 64-bit ?
