• 186 views | 1 messages Discussion: LEAP
    Topic: Problem with mixed Transport fuels and CO2 Subscribe | Previous | Next
  • Gregers Larsen 6/11/2018
    Hello LEAP people!
    In my model I use Stock-turnover for my Transport (Transport method). That means my input is defined in vintages of vehicles, not the average as otherwise.
    I want to implement mixed biofuels (Biodiesel mix and Gasoline-Ethanol mix) to my model. Since all vintages will transition to these fuels, I cannot define it as two fuels under the vehicle type (as I would do for PHEV's)
    Instead I'm defining a new fuel in Secondary Transformation. Let's use Biodiesel mix as an example:
    My biodiesel mix fuel consists of two fuel; biodiesel and diesel, mixed with a changing ratio over the years. in 2020, it's 10% biodiesel, in 2050, it's 40%.
    Now all my vehicles run on biodiesel mix and all is good. Primary Requirements for the vehicle type shows the right allocation between bio and oil, great. If I show final demand, the model shoes me the "biodiesel mix" demand, which is ok.
    But here's the issue: When I show non-biogenic CO2 in Results, my mixture is defined as 0. This is as there is not defined any carbon contents in the "Fuels" menu. However, my mix changes, so I cannot define a fixed carbon content.
    What can I do for implementing a mixed fuel in gas station pumps?
    Gregers Larsen
