• 402 views | 3 messages Discussion: LEAP
    Topic: Error Invalid Fuel Specified for device Subscribe | Previous | Next
  • Andrés Benito 8/20/2018
    Hello Community,
    Someone would please help me with the error I'm attaching an image??
    It shows up when trying to run the results.
    Thanks in advance.
    Andres
    Attachments:  Error - Invalid Fuel2.pdf [12]
  • Charlie Heaps 8/21/2018
    Hi Andres - could you send me your data set (send to leap@sei.org)?  Please attach as a ".leap" file.  You can use the email button in LEAP to do this.
    It looks like your data set has become slightly corrupted.  I may be able to fix it.
  • Andrés Benito 8/22/2018
    Hi Charlie, thanks a lot for your time and answer.
    I thought I was able to fix the error because I re-entered the information as a new area, so it seems everything was working just fine, but I left to the end what I suspected was the issue.
    The error comes up when trying to add a new fuel (Residual Fuel Oil)  to an existing power generation process, which works with Natural Gas as well, at the Transformation branch.
    I think I'm misunderstanding the application of Residual Fuel Oil for power generation processes, may be it just could be added for residential demand purposes. Moreover, once I deleted the new fuel (Residual Fuel Oil) from the generation process, tending to undo the action, the Residual Fuel Oil as a Secondary Resource doesn't deleted or suppressed.
    Fortunately, I've been working with the "Make Version" tool, in order to revert these possible mistakes of my own.
    Thanks again for your time and I apologize if the inquiry is too basic.
