• 284 views | 2 messages Discussion: LEAP
    Topic: Insert branches from other area Subscribe | Previous | Next
  • Anilkumar Katta 9/10/2018
    I have two LEAP files and tried to insert the demand branches from one area to another. I chose the mappings for the scenarios, fuels, regions etc but the regions are getting mapped wrongly (Region not mapping to the region I choose but to a different region). I can share both the files if you can share the email id. Can you please look into the issue?
    Thank you,
    Anil Katta
  • Taylor Binnington 10/10/2018
    Hi Anilkumar -
    Sorry for the long wait. I've tested this on my computer using a simple test case, but cannot reproduce the issue. Would you be able to send the following to leap@sei.org?
    1. A copy of your main LEAP model,
    2. A copy of the LEAP model containing the branches that you want to insert into the main LEAP model,
    3. A description of the configuration that you use to import the branches from one into the other (with a description of each step in the import process).
    Thanks so much,
