• 101 views | 2 messages Discussion: LEAP
    Topic: LEAP not opening Subscribe | Previous | Next
  • Hadrian Vivek 11/20/2018
    I installed the tool, however, it is not opening. Do I need open the tool via command prompt?
  • Emily Ghosh 11/26/2018
    Hi Hadrian,
    The LEAP file is installed in the following folder: C:\Program Files (x86)\LEAP\Leap.exe. If installed properly, you should be able to open LEAP directly from the Windows Start menu.
