• 552 views | 5 messages Discussion: LEAP
    Topic: Problems in linking WEAP and LEAP Subscribe | Previous | Next
  • Barbara Suzart 11/26/2018
    Hello! I'm working with WEAP and LEAP and to continue the work, I need to link the data from both softwares. However, I can not find the "Link to WEAP Water Model" option in LEAP, as shown in the WEAP-LEAP tutorial. I would like to know how I can link both softwares.
    Thanks in advance for your cooperation.
    Sincerely,
    Barbara Suzart
  • Emily Ghosh 11/26/2018
    Hi Barbara,
    You should be able to find the "Link to WEAP Water Model" button under the "Advanced" menu.
  • Barbara Suzart 11/30/2018
    Hi, Emily!
    Thank you so much for replying! The point is that the "Advanced" option does not appear in the menu. Is this because my program is outdated?
    Sincerely,
    Barbara Suzart
  • Emily Ghosh 11/30/2018
    Hi Barbara,
    So sorry, I misunderstood your first post. The 64-bit version of LEAP has been having issues with the Advanced menu not showing up. If you have a small data set, I recommend downloading the 32-bit version of LEAP instead (here is the download link).
    Alternatively, there is a workaround that you can use to show the Advanced menu in the 64-bit version. To do so, follow the instructions from the last post in this thread: https://www.energycommunity.org/default.asp?action=thread&tid=3984&fid=22
  • Barbara Suzart 12/3/2018
    Hi, Emily!
    I downloaded the 32-bit version of LEAP and the "Advanced" option is in the menu.
    Thank you so much for the support!
    Barbara Suzart
