• 494 views | 4 messages Discussion: LEAP
    Topic: Error in 2.1.2 section Result: Endogenous capacity addition Subscribe | Previous | Next
  • Sahana Lokesh 11/28/2018
    Hi, I finished all the steps in 2.1.2 training exercise which is adding data to the Reference Scenario for the Industry branch. But when I click on Results, I am getting the error "Problem with endogenous capacity addition calculations".
    I have attached the error message herewith. I went back and checked all my input data but I could not find any mistake. Kindly help me resolve this issue.
    Also, I have read through your previous suggestions for Endogenous capacity additions, but I am unable to find Maximum Build Capacity variable.
    Kindly let me know where to actually see it on the software.
  • Emily Ghosh 12/4/2018
    Hi Sahana,
    This error typically notes that the demand is growing too fast. I would start by checking the demand results to ensure they match the results in the training materials. To do this, turn off Transformation and Resources from Basic Params, re-calculate the results, and check the results sector by sector to ensure they are correct (be sure to check the scale and units!). Once you have fixed the issue, turn the Transformation and Resources branch back on.
  • Pedro Gerber 6/3/2019
    I also had that problem. thanks for your response
  • Izzet Ari 5/9/2021
    Many thanks, I had the same problem. But now it is fixed.
    Thanks
    İzzet
