• 559 views | 3 messages Discussion: LEAP
    Topic: Problem in writing code using vb in excel. Subscribe | Previous | Next
  • Ahmed Alaadin 11/28/2018
    when trying to write the tutorial commands in the immediate window  in vb script editor in excel the error message attached appears. would you help me out?
  • Emily Ghosh 12/4/2018
    Hi Ahmed,
    I wasn't able to reproduce your issue. Are you using the latest version of LEAP? If not, feel free to download it through the following link as the issue may have already been resolved: https://www.energycommunity.org/default.asp?action=download
    If you have a small dataset, I recommend downloading the 32-bit version of LEAP. If you continue to have an error, please let us know.
  • Arahman Khalidi 4/5/2021
    I installed the tool, however, it is not opening. Do I need open the tool via command prompt?
