• 606 views | 4 messages Discussion: LEAP
    Topic: Minimum addition size constraint in Optimization Subscribe | Previous | Next
  • Ankit Gupta 11/29/2018
    Hi!
    I have a provincial electricity model with 11 generating technologies shown in the screenshot. I am facing a problem while running the optimization mentioned below:
    There are two cases:
    1) Without entering any data in minimum addition size(MAS) constraint: The optimization runs perfectly without any error.Awesome!
    2)With entering data in MAS constraint: The optimization is not running with an error "no primal solution". In one case, I entered only 1MW for hydroelectric generation technology while rest were zero. Even after, I am getting the error. Since 1MW is the default addition size in the LEAP. I am not able to understand why I am getting an error.
    Please help!!
  • Emily Ghosh 11/29/2018
    Hi Ankit,
    The message "No Primal Solution" occurs if there are conflicting constraints. I recommend checking if the value in the Minimum Capacity Addition variable is smaller than the Maximum Capacity or Maximum Capacity Addition variables, otherwise you will get this error.
  • Ankit Gupta 11/30/2018
    Thanks, Emily
  • Pulkit Kapoor 12/25/2018
    Hi, How can we add minimum addition size constraint/variable?
