• 850 views | 6 messages Discussion: LEAP
    Topic: ERROR! Subscribe | Previous | Next
  • Alperen Sari 1/24/2019
    While i try to calculate my analyse i have an error message which sent you with attachment. I do not understand and i can not solve the error. How can i solve this fault?
    Attachments:  LEAP.pdf [10]
  • Emily Ghosh 1/25/2019
    Hi Alperen,
    Unfortunately, the cause of the of the Range Check error is hard to determine from the error message alone. If you are unable to resolve the error yourself, feel free to email a copy of the LEAP file for us review. To do this, go to "Area:Backup" to create a .LEAP file, then either reply to this message and attach the file, or email it to leap@sei.org.
  • Alperen Sari 1/26/2019
    Thanks Emily, I decide to re-model my analysis from beginning. I hope I won't make mistake and I won't take any ERROR message :) If I have any problem I will inform LEAP again. Thanks again, LEAP team give very fast support.
    Alperen
  • Alperen Sari 2/3/2019
    I am unable to resolve the error myself and as you recommend I send it. While view the results, if I use the level 1 there is no ERROR, but if I choose level 2, level 3, level 4, level 5, level 6 or level 7 the Range check Error appears on the screen.
    Attachments:  SEA.leap [3]
  • Taylor Binnington 2/12/2019
    Hi Alperen -
    Using this model, try the following (you may see some errors appear along the way - click "Continue LEAP" and proceed with the steps below, if you can)
    1. Click on Results.
    2. Click "Auto Refresh" above the tree, to disable it.
    3. from the menu below the chart, select "Years > All Years", even if it appears to be selected already.
    4. Reduce the number of levels (above the chart) to 1.
    5. Click "Auto Refresh" above the tree, to enable it.
    6. Above the chart, select "More" (if not already selected) and unselect the "Group Small" option.
    This should get you back to the beginning where you can configure results. Let me know fi you have any other troubles,
  • Alperen Sari 2/13/2019
    Thanks Taylor, It works.
