• 609 views | 4 messages Discussion: LEAP
    Topic: Can't add emissions Subscribe | Previous | Next
  • Marie Desatnik 3/7/2019
    Dear community,
    I have some issues adding emission effects to diesel technologies in of my categories, it simply does not show. Any advice why this may be?
    Thank you!
    Kind Regards,
    Marie
  • Taylor Binnington 3/13/2019
    Hi Marie -
    What, in particular, does not show? The emission factor branch, or the Avg Environmental Loading variable?
  • Marie Desatnik 3/25/2019
    Thank you for your reply. This is the option I receive. ​Can't figure out why...
    Kind Regards,
    Marie
  • Taylor Binnington 4/2/2019
    Hi Marie -
    This window is asking you to select an example technology from TED. Once you navigate through the tree to select a technology that you deem appropriate and press Okay, LEAP will add the emission factor branches associated with it into the tree. Only then will you see the emission factors.
    Is that clear?
