• 726 views | 5 messages Discussion: LEAP
    Topic: debug.txt file not found Subscribe | Previous | Next
  • Agnes Kelemen 3/19/2019
    Hi, if I get the message 'error: debug.txt file not found' when running the model in optimisation mode, is that a bug, or is it an error in the model? Thank you for your help.
  • Emily Ghosh 3/20/2019
    Hi Agnes,
    This is not a common error, so it is hard to say without seeing the file itself. Have you tried restarting LEAP? If that does not help, if you would like, please feel free to e-mail your .LEAP file to leap@sei.org and we can take a look at the issue. To create the .LEAP file, just go to Area: Backup.
  • Agnes Kelemen 3/24/2019
    Hi Emily,
    I sent the file by email and have also attached it here. Thank you for your help.
    Agnes
  • Emily Ghosh 3/26/2019
    Thanks Agnes. I received the file and will take a look at it today.
  • Emily Ghosh 4/1/2019
    Hi Agnes,
    I have reviewed your file, and was unable to reproduce the problem. It does not appear to be a problem with your model, but likely related to your LEAP installation. Prior doing a full reinstallation, I suggest to delete the area from your computer and then reinstall the area from the .LEAP file you sent us. To delete an area, go to Area -> Manage Areas, then find the file you are working on and delete it.
    If this doesn't work, try uninstalling LEAP through Add/Remove programs, and then reinstalling it. Be sure to use the latest version of LEAP, which is found here: https://www.energycommunity.org/default.asp?action=download
    If you continue to have problems, please let us know.
