• 823 views | 6 messages Discussion: LEAP
    Topic: Power generation cost Subscribe | Previous | Next
  • Wu Xiaoyang 4/3/2019
    I want to get the cost of power generation. What should I do and what will be included in the cost of power generation I will get after doing this?
  • Emily Ghosh 4/15/2019
    In order to evaluate power sector costs, you will first need to enable cost calculations in LEAP by going into Basic Params: Scope & Scale and checking the "Costs" checkbox under Scope. After doing this, you will see cost variables at each branch. In the Transformation Process branches, additional variables can include Capital Cost, Fixed O&M Cost, Variable O&M Cost and Stranded Cost. In the Transformation Feedstock Fuel branches, you will see a Fuel Cost variable. You will need to input unit cost data into these variables in order to do a power sector cost analysis.
    You can also set the cost boundary through Basic Params: Costs. If you are only interested in the power sector, change the "Cost-benefit Calculation Boundary" to the transformation module associated with this sector. You can also input a Discount rate and Inflation rate, and choose a Capital cost Annualization Method in this tab.
    Once you have entered cost data and parameters, you can view cost results in Results View.
    For more information on the above, refer to the following help pages:
    I also recommend reviewing training exercise #6 to familiarize yourself with LEAP's costing features. Here is the link to the training materials:
  • Wu Xiaoyang 4/18/2019
    Thank you very much!
    I also want to know what to do if there is no historical output in the power generation module?
  • Emily Ghosh 4/18/2019
    Hello - If you want to include historical data in your transformation module, make sure you set the First Simulation Year to the year you want LEAP's calculation to start from. If you set the First Simulation Year to the base year, the Historical Production tab will not show.
    For example, say that you have historical data from 2005 to 2013, and you want LEAP to start its calculations from 2014 onwards. If your Base Year (in Basic Params) is set to 2005, and you write "BaseYear" in the First Simulation Year variable, the Historical Production tab will not show (which is like the screenshot you gave). If you write "FirstScenarioYear" in the First Simulation Year variable, the Historical Production tab will now show, and you should be able to include historical data.
  • Wu Xiaoyang 4/20/2019
    Thank you!
    I made a mistake in the analysis of the results.
    As you can see, I still got an error after adding the density value. In fact, I did not use Non energy, and I successfully conducted the result analysis last night. I don't know how to solve this problem.
  • Taylor Binnington 5/6/2019
    Hi Wu -
    In your tree, check where the fuel "Non Energy" is produced or consumed, and ensure that no variables (include any environmental loadings you may have assigned) are specified per unit of mass, or per unit of volume. Like for electricity, mass and volume are not defined for this fuel.
