• 314 views | 2 messages Discussion: LEAP
    Topic: Transportation Questions Subscribe | Previous | Next
  • Aron isaac Ansay 4/6/2019
    1. I'm trying to use Device share in order to specify the biofuel blending for vehicle fuels. How does it work with Fuel Economy and Mileage tabs? For Example, I set 90% Gasoline and 10% Bioethanol for a vehicle, how will this affect the input for fuel economy and mileage? If the total mileage is for example 20,000 kilometers per year, do I put 18,000 km for gasoline and 2,000 km for ethanol or just 20,000 km for both fuels under a same device? Same with fuel economy, if I input 10 km per liter,  is it 9km/L for gasoline and 1km/L for bioethanol or just 10km/L for both?
    2. I wish to set my survival profile to constant for sales share and stocks share since I have data points for all years but when I do, I get the following error:
    I have set my scrappage to 0 and max scrappage fraction to 100.  I'm getting results when I set the lifecycle profile for stock share to the default LEAP vehicle survival profile but getting the error when changed to constant.
    3. Also, whenever I'm in my desktop, my LEAP can generate results but when I'm in my laptop, it can generate results from the copied LEAP Areas folder too except when I edit something, it generates the error below.
    4. Also, I've put a baseline scenario under the current accounts, but when trying to add and edit another scenario, and even in the baseline scenario, I am not able to change the stocks. Only sales are changeable under scenarios.  Is there anything wrong in my process of adding scenarios? I need to change the stocks of vehicles for some scenarios.
  • Taylor Binnington 5/6/2019
    Hi Aron -
    Before getting to your specific questions, have you worked through exercise 5 of our basic training materials, here?
    This exercise covers stock turnover analysis in LEAP, and I think would answer some of your questions.
