• 303 views | 3 messages Discussion: LEAP
    Topic: cannot change mappings for scenarios when using "Insert Branches From Another Area" Subscribe | Previous | Next
  • Junping Ji 4/16/2019
    Hi, I'm using LEAP 2018.0.1.24 (32-bit). I follow the instructions in the Help section of "Insert Branches From Another Area", but I cannot change mappings for scenarios. Did I miss something? Thank you!
    1. I select "Choose Mappings for Each Scenario"
    2. Then I change the mappings, only keeping the Reference and Mitigation scenarios and dropping others.
    3. The resulting message says LEAP imported 7 scenarios instead of 2 scenarios (Reference and Mitigation).
  • Taylor Binnington 5/28/2019
    Hi Junping -
    This has been fixed in the latest version of LEAP. You can download it here:
    https://www.energycommunity.org/default.asp?action=download
  • Junping Ji 5/28/2019
    Hi Taylor, thank you very much!
