• 400 views | 4 messages Discussion: LEAP
    Topic: Fuel Switching and CCS retrofit costs Subscribe | Previous | Next
  • Humberto Lopez 5/3/2019
    I am struggling to find a way to model fuel switching and CCS retrofitting for power plants in LEAP. Is there any available method?
  • Taylor Binnington 5/28/2019
    Hi Humberto -
    You have a few options: you can either modify the characteristics over time of an existing process (which represents a power plant in your transformation module), or, you can displace an existing process with a new one that consumes a different fuel or has different emission factors.
    To model CCS, you would likely want to modify the "Avg Environmental Loading" variable for Carbon Dioxide, which you should already have attached to each of the plant's feedstock fuels.You might also consider modifying the plant's Process Efficiency or any of it's cost variables, to represent the different characteristics of CCS plants.
    To model fuel switching, you would modify the list of feedstock fuels that a plant consumes (note that you may add others as you would any branch in the tree). Each fuel has "Feedstock Fuel Share" variable, which you may modify as you like.
    Good luck,
  • Humberto Lopez 6/12/2019
    Thank you very much. Another quick question that I wanted to ask, LEAP offers two solvers GLPK and CPLEX which is the main difference between these two? Can I still run an efficient optimisation with the GLPK solver?
    Kind regards,
    Humberto
  • Taylor Binnington 6/17/2019
    Hi -
    GLPK is free and open-source, and so we can package it together with LEAP. CPLEX is not free, and so you need to obtain it separately from LEAP. But it solves problems much faster than GLPK.
