• 239 views | 2 messages Discussion: LEAP
    Topic: GHG emmissions Subscribe | Previous | Next
  • Adan Zahid 7/11/2019
    i am not getting results for GHG emmisions . how to solve this issue ?
  • Georgia Savvidou 7/18/2019
    Hi Adan,
    From your question I am not sure whether you
    1. have properly added emission factors under Analysis View and you are having a problem configuring results under the Results View, or
    2. whether you are having a problem adding emission factors.
    Here you can find information on how you can add emission factors in your model. After you have added emission factors, go to Results View, choose Environment: All Effects from the Results Selection Box and ensure the chart legend on the right has "All Effects" selected. To view the global warming potential (GWP) of GHGs in your model, you may also select one of the GWP result options in the list.
    Please note that the outputs seen in Results View depend on the branch you have selected from your tree. For example, selecting specific branches with your mouse, such as "Demand" or "Transformation", will show you the emissions aggregated under these branches.
    Generally and when creating new topics on these forums, please be as specific as possible in describing your question. You should include a complete description of your issue, the steps you took to observe it, and why the result is unexpected to you/what you've tried already to fix it. Without this information, it's difficult for us to provide useful guidance to you.
    Georgia
