• 508 views | 3 messages Discussion: LEAP
    Topic: comparison results issue Subscribe | Previous | Next
  • Ali Tamoor 10/9/2019
    as you can see the picture i have obtained results on reference scenario but the results are not right as shown in training manual. please guide where i did the mistake.
    query 2:
    i want to compare it now. for example for better production and optimization if i take some assumptions in order for betterment like reducing the coal production, increasing the use of natural gas and hydro etc for production of energy how i can show their results in one graph or may be in two. do i have to take another scenerio based on assumptions
  • Emily Ghosh 10/10/2019
    Hi Ali,
    Have you compared the results in the training exercise to the Energy Balance in LEAP? This can help you determine where you may have inputted a value incorrectly. Start from the bottom by checking the demands, and then work your way up through the T&D module, Electricity Generation module, etc. If the problem is related to the Electricity Generation module, make sure that you have correctly specified the Exogenous and Endogenous Capacity so that enough capacity is being added to meet demands.
    If you are unsure of what to input, you can always compare your model to the completed version of Freedonia that is built into LEAP. First, save your working model, then go to Area: Open from LEAP's main menu to open the Freedonia model. Then, select Area:Revert to Version to view the exercise you are on.
    With regards to your second question, you can create new scenarios under the Reference scenario to assess different energy policies. For example, if you no longer want coal power plants to be built in the future, create a new scenario through the Scenario Manager, change the Exogenous Capacity of all coal power plants to 0 at some point in the future, and remove coal from the Endogenous Capacity variable. Exercises 4 and 6 of the Training Exercises reviews how to create new scenarios, and how to compare them in LEAP. Also, take a look at the Results and Scenario video tutorials for more information: https://www.energycommunity.org/default.asp?action=videos
  • Ali Tamoor 10/15/2019
    i am checking and comparing the inputs with freedonia model. i want to know that i am not adding industry, commercial and trasnport sector in demands will it change the graphs of transformation and resources tree because the input data for transformation and resources tree is kept same as freedonia
