• 406 views | 3 messages Discussion: LEAP
    Topic: Exporting Scenarios names (LEAP API) Subscribe | Previous | Next
  • Andre Siqueira 10/18/2019
    I'm trying to export all the scenarios to excel using the code below:
    For s = 3 To L.Scenarios.MaxID
    Worksheets("Sheet1").Range("C1").Offset(m1, t1) = L.Scenarios(s).Name
    t1 = t1 + 1
    But using the "L.Scenarios.MaxID" it's not working. Then, I need to manually enter the number of scenarios that I have. Is there a way to make it smarter?
    I have 8 scenarios in my model, but when I print the value of L.Scenarios.MaxID it returns me 11. The program works well until the 8th item.
    Thank you!
  • Emily Ghosh 10/21/2019
    Hi Andre,
    Scenarios.MaxID refers to the ID number of the last scenario. If you are looking for the total number of scenarios in your model, you should use Scenarios.Count.
  • Andre Siqueira 10/21/2019
    It's working!
    Thank you!!!
