hi Everybody,
LEAP is trying to help you out by telling you that you have specified an inconsistent set of values there.
Thank you for your kind reply Sir.
Hi Siddiqua,
1 Like Hi again - As you can see, the negative value is for the branch with the Remainder(100) function. Because the other values all add up to more than 100% in future years, that forces the remainder function to yield a negative result (because it is defined as 100 minus the sum of all the other neighboring branches). This causes LEAP to report an error (because shares are not allowed to be less than zero).
Thank you Sir. I got your point. But if i want to give some formula to calculate the growth rate for future years, what should i do then?
