LEAP is a very flexible system. You can model it whatever way you want.
In your specific case, you do not need to combine the generation technology from gas and oil in one. You are ought to, as technologies are different, create different processes fro example Oil Combustion Turbine and Natural Gas combustion Turbine separately. In addition, if you sought to more in depth analysis of every power plant, you can create a branch for each power plant as well, which would help not only to separate power plants by type but also their specific lifetime, efficiencies, and other parameters including future interventions.
Hope this will help you out.
