Hello
I am trying to forecast the Colombian power mix by 2040.
As input, I am using annual electricity forecasts of Colombia, from 2019 to 2040, so I enter this information as a total energy data (red gear icon). System transmission and distribution losses, planning reserve margin, system energy load shape (for entire system % of annual generation), different generation technologies are also used as inputs. For each generation technology, process efficiency, lifetime, efficiency, historical production, exogenous capacity, merit order, and maximum availability are entered.
In addition, some generation technologies are partially removed (at some point in the simulation period) and new ones added (I use the endogenous capacity to include new technologies).
When I run the model, the results are erratic: the energy generated does not match the energy demand. Any suggestions or advice on what should I do in order to solve this problem?
I attach Images of the results I got and the .leap file.
Thank you in advance for your assistance in this issue.
Hi Jose,
