Unfortunately, now I got the same diagnostics message but it said: "Optimization unable to build all needed capacity in and after the year 2019". right after my base year.
However, I want to make sure "unserved" that you mentioned do related to the "unmet requirements"?
In my simulation, all of the requirements are met. The results on the capacity and outputs have seemed fine. Please see the file attached.
But, I set a constraint for each year and for each power generation technology in "maximum capacity". this is because when I simulated my simulation without any constraint, LEAP choose one technology (for example hydro pumped storage) and it has a large amount of capacity. and it seems not realistic with my country's condition. If I set constraint only for that technology, LEAP chooses another technology (example: biomass municipal waste) and again, put a large amount of capacity only in that technology. And then I put constraints for every technology that I used.
And now, my question is, if I've done my simulation using that way, is it possible the diagnostics message occurred due to I set constraints for all power generation? and if I set constraints that way, can we still call that simulation optimized?
and it's good to hear LEAP will release the new version of LEAP soon. can't wait for that.
Thank You,
Kind regards,
Etis Meilandari
