• 876 views | 5 messages Discussion: LEAP
    Topic: new name of the model Subscribe | Previous | Next
  • Biljana Stojanovic 5/6/2020
    I had build one model, but now I'm using the first model for new modelling. I have rename it with 'save as', but when I run the results, in results view, above the branch the old name appears.
    Can you please point out how the change this.
    Thank you in advance.
    Biljana
  • Charlie Heaps 5/6/2020
    >>I had build one model, but now I'm using the first model for new modelling. I have rename it with 'save as', but when I run the results, in results view, above the branch the old name appears. Can you please point out how the change this.
    By design, the top level branch name does not automatically update when you use the Save As function. However you can manually change the name by single clicking on the tree branch once in Analysis view. Wait about a second, then single click on it again. You can then edit the name directly on the tree.
    Good luck!
  • Biljana Stojanovic 5/7/2020
    Hi Charile and thank you for your answer.
    Interestingly, but in my model the model name does not appear in the analyses view, only in the results view :). That's why I can not change it.
    Any tip is wellcomed.
    Biljana
  • Charlie Heaps 5/7/2020
    Sorry - I forgot to mention this. If you don't see the top level branch in Analysis View, right click on the tree and select "Show Area Branch".
  • Biljana Stojanovic 5/11/2020
    Thank you so much, it was very base issue but I could not resolve it.
    Thank you once again.
    All the best,
    Biljana
