• 1301 views | 7 messages Discussion: LEAP
    Topic: NEMO Subscribe | Previous | Next
  • Felicia Sutomo 5/24/2020
    Dear All,
    I have updated the LEAP 2020 version and wanted to try the storage analysis. I have installed NEMO and have switched the optimization to NEMO CPLEX (I have CPLEX Solver and have been using it for LEAP previous ver). I just opened the  optimization exercise module and added storage analysis in the template.
    But when click the result analysis, there is error message : failed to run JULIA/NEMO branch: transformation/electricity generation. The error message is similar when I switched to optimization NEMO GLPK. Could you please help me solve this issue?
    Thank you.
    Felicia
    Attachments:  error NEMO.pdf [11]
  • Charlie Heaps 5/24/2020
    Hi Felicia - this sounds like a teething problem with LEAP2020.  I think that message indicates that LEAP is unable to "see" Julia.  Would you be able to do a quick zoom or skype call with me to investigate further?  Meantime, can you copy and paste the contents of the Help:About screen so I have more info on your PC and LEAP setup?
    Please email me at charlie.heaps@sei.org so we can setup a call.
  • Wulf Boie 5/27/2020
    Hi Charlie
    I have the same problem but with the GLPK solver. I tried it with my own file and with the optimisation example delivered with LEAP 2020 but get the same error with both files.
    best regards
    Wulf
    Attachments:  Optimisation problem.pdf [7]
  • Charlie Heaps 5/27/2020
    Thanks Wulf - I am going to investigate further today and will get back to you both ASAP.
  • Felicia Sutomo 5/27/2020
    Hi Charlie,
    Please see the content of LEAP-about below.  I have reinstalled the NEMO but the result is same. I`m waiting for your feedback.
    Thank you.
    Felicia
    System Information
             Version: 2020.1.0.2 (64-Bit)
             Dictionary Version: 455
             Program Folder: "E:\Program\LEAP2020\"
             Areas Folder: "C:\Users\User\Documents\LEAP Areas\"
             Settings Folder: "C:\Users\User\Documents\LEAP Areas\_Settings\"
             Instance: 1
             MapWinGIS Installed: No
             Registered for Automation: No
             TSC64 64-Bit DLL for Scripting: No ()
             GLPK: 4.65 (64-Bit)
             NEMO: Yes
             Julia: "C:\Users\User\AppData\Local\Programs\Julia\Julia-1.4.0\bin\"
             Registered to: "feliciasutomo91@gmail.com" until November 13, 2021
             User Name: User
    Current Area
             Area Name: Optimization Exercise2020
             Base Year: 2010
             End Year: 2020
             First Scenario Year: 2011
             Scope: [Demand, Transform, Costs, Emissions]
             Scenarios: 6 (COAL, OPT, GAS, WIND, HYDRO, CO2)
             Time Slices: 8 (Winter Day, Winter Night, Spring Day, ...)
    Microsoft Windows
             Version: Windows 10 Education, 64 Bit
             Windows Directory: C:\WINDOWS
             Running as: Standard User
             BDE Installed: No
             Excel Installed: Yes
             Word Installed: Yes
             PowerPoint Installed: Yes
             Wine: No
             Screen Resolution: 1280 x 720 pixels
             Date Format: m/d/yyyy
             List Separator: ","
             Decimal Separator: "."
             Thousands Separator: ","
             Internet Explorer: 11.1488
             Fonts: Small fonts (100% Scaling)
             Anti-Virus: Kaspersky Internet Security (Disabled, Up to date)
             Anti-Spyware: Windows Defender (Enabled, Up to date)
             Firewall: Kaspersky Internet Security (Disabled)
    Computer
             PC Name: FELICIA
             Processor: Intel Core i5-4300U CPU @ 1.90GHz
             Processor Speed: 2494 MHz
             Number of Processors: 4
             Total Memory: 3.88 GB
             Available Memory: 1.66 GB
             Disk Size: 96.34 GB
             Free Disk Space: 31.73 GB
             Connected to Internet: Yes
  • Charlie Heaps 5/28/2020
    Hi again Felicia,
    I think we've found the issue.  There is a file called tee.exe in the LEAP program folder that isnt being properly run by the batch file created to run NEMO.  Please try copying this file (tee.exe) to the \Windows directory (or the \Windows\System32 directory).  That should get the system up and running again.  Please let me know if this works.
    I will do a more permanent fix for this in the next dot release.
  • Charlie Heaps 5/30/2020
    I've uploaded LEAP2020.1.3 now.  This should fix the problem with LEAP not running NEMO properly and also fix the problem with importing hourly load shapes when using time slices with 2 (day/night) or 4 (morning, day, evening, night) daily time slice groups.
    Please update and see if it helps with your issues.
