• 426 views | 2 messages Discussion: LEAP
    Topic: Where are my original leap file Subscribe | Previous | Next
  • Bowei Sun 5/24/2020
    After I updated my software, I find my original manuscripts have disappeared, they have been saved. But they are not found in the new version.
  • Charlie Heaps 5/25/2020
    Hi Bowie,
    Make sure your LEAP areas folder is the same as used in LEAP2018. The default in both versions is C:\Users\charl\Documents\LEAP Areas
    Go to the Settings: Folders screen and check the folder listed for Areas. If need be you can change this to point to where your existing areas are stored. After doing that you will need to restart LEAP.
    Please reply here and let me know if this works.
