• 641 views | 3 messages Discussion: LEAP
    Topic: LEAP update error Subscribe | Previous | Next
  • Kyawmoe Aung 8/19/2020
    Hello LEAP progam experts,
    I have updated LEAP and the error appear after update. Can someone give me a hint or should I uninstall and reinstall the software. Because I can't open LEAP with this error.
    FYI, I am using Window 10, LEAP 64 bit
  • Charlie Heaps 8/21/2020
    I'm assuming you just updated to LEAP2020.1.16. This may be due to LEAP failing to unzip the dictionary files over the previous version. That in turn may be down to a rights issue. I would suggest doing a full download of LEAP again from here: https://leap.sei.org/download Then run the setup program with full admin rights enabled.
    If this does not work, you may also want to temporarily disable your anti-virus package in case it is interfering with the installation. ESET anti-virus seems to be particularly problematic.
    Good luck!
  • Kyawmoe Aung 8/22/2020
    Thanks Charlie.
    I have downloaded and uninstalled previous version and reinstalled latest version. It works.
    Thanks for your kind help.
    Kyaw Moe Aung
