• 342 views | 2 messages Discussion: LEAP
    Topic: Calculation diagnostic messages when viewing results? Subscribe | Previous | Next
  • Daniel Liu 12/2/2020
    When I try to view results, there is a message in the diagnostics section that says "Dispatch exceeded plants rated availability".
    How can this issue be solved?
  • Charlie Heaps 2/18/2021
    This diagnostic message usually occurs when the data you enter in the Historical Production variable is inconsistent with capacity and maximum availability variables. In other words you have entered values for three variables that are inconsistent with each other.
