• 613 views | 3 messages Discussion: LEAP
    Topic: Import Energy Balance from IEA Subscribe | Previous | Next
  • Amin Gharibi 1/20/2021
    Hi, I wish you're in great.
    I want to know is there any way to import available data energy balance from IEA without writing data one by one?
    Thank you alot.
  • Charlie Heaps 1/27/2021
    Hi Amin,
    There is not directly, but if you first export the IEA balance to Excel in a format where results are ordered with years shown in columns then you can easily copy and paste each row of time series values into LEAP.  Bear in mind though that LEAP is probably more useful for generating energy balances (both historical and projections).  That is, energy balances are a key output from LEAP rather than an input.
    I would also suggest having a look at this video, which takes you through the many different techniques for importing data into LEAP:
    https://www.youtube.com/watch?v=y4b2KCIxOJU
    I hope this helps!
  • Ifechukwude Chinye-ikejiunor 1/31/2021
    Hello Amin,
    I would also like to add that while loading/importing the file from excel into LEAP remember to assign names to the columns with the Manager tool in Excel.
    To navigate here, click on the formula bar then you can find it.
    good luck!
    Ifechukwude
