• 1022 views | 7 messages Discussion: LEAP
    Topic: problem in run the "registerLEAP.bat", and unable to activate the "run area script" Subscribe | Previous | Next
  • Rupu Yang 1/29/2021
    When I try to run the "registerLEAP.bat" by the administration role, it gave me errors.
    1. Leap.exe/regserver
    'leap.exe' is not an internal or external command, nor is it a runnable program or batch file.
    2. Module tsc64.dll load failed.
    How can I get it fixed? And that's the reason why I cannot activate the "run area script" ?
  • Charlie Heaps 2/3/2021
    Hi there - make sure you are running those commands from the command prompt after you first change the active folder to your LEAP program folder (typically c:\program files\leap for the 64-bit version of LEAP). Make sure that you have full admin rights when running the batch file.
    I hope this helps,
  • Valentine Wambui 2/26/2021
    Hey,
    I am also experiencing errors when i run the registerleap.bat file with full administrative rights. Error is : The module "tsc64.dll" failed to load. Make sure the binary is stored at path or debug ...specified module could not be found..
    Kindly assist.
    Thanks
  • Valentine Wambui 2/27/2021
    Hey resolved this problem by downloading the 32 bit version instead.
  • Charlie Heaps 2/27/2021
    Hi folks - see my above message, but as further clarification. If you see a message from Windows saying that something is not an internal or external command, that means Windows could not find the executable file. This tends to happen if you have not changed the active folder to program files\LEAP (or the place where you installed LEAP) Make sure you do that by entering command
    CD c: \program files\LEAP
    Do this before you run registerleap.bat
    But note that you must have opened the command window with full admin rights for this to work.
  • Ben Brida 4/27/2021
    Dear Charlie
    I tried to follow the instruction you provied here as I am facing the same problem with 64 bit version. Unfortunately it has not solve the problem even running the command with full administrative privilieges. I still get the same error message.
  • Charlie Heaps 4/28/2021
    See my answer in other thread.
