• 251 views | 2 messages Discussion: LEAP
    Topic: Debug Subscribe | Previous | Next
  • Pravesh Raghoo 2/7/2021
    I am running a LEAP-OSeMOSYS file and I get the following Error:
    Unable to delete file: "C:\Users\Owner\Documents\LEAP Areas\_Settings\_Work\0\OPDebug.txt" (Abort, Retry and Ignore as options). Abort end the process, Retry shows me the same Error, and Ignore shows me an error in LEAP.
    What do I do in this case?
  • Charlie Heaps 2/18/2021
    These messages can sometimes occur if some other software is aggressively scanning files while LEAP runs. I have found that some antivirus tools such as AVAST, ESET and AVG are particularly problematic. One option is to temporarily disable these tools to test if the problem goes away. Another option is to configure your antivirus tools to tell them to avoid monitoring the LEAP Areas folder (and its subfolders). You will need to consult the manual of whatever anti virus tool you are using for help with this.
