• 273 views | 2 messages Discussion: LEAP
    Topic: IBC calculation results- very high temp change Subscribe | Previous | Next
  • Valentine Wambui 3/4/2021
    I have checked off indicators and health effects in settings- immediately i leave the page and re-enter settings- the IBC tab is not there. The area is IBC compliant though.
    I cannot see the Benefit Calculator Results folder  neither do I see this folder in Asiana. The results are available though.
    The temperature change due to cooking energy demand ( 255 mill GJ) is around 3.7degreesC and rises to 12.8 in BAU in 17 years,  which seems unrealistic,...any ideas on why i would be getting this high value?
    Any assistance is appreciated.
    Valentine
  • Charlie Heaps 3/12/2021
    As noted a while back, there is an issue with scaling factors for the climate/temperature indicator in the Asiana data set. They are supposed to read "thousandths" of a degree C (i.e. 10-3) but are set to "degrees C".  You can work around this by simply entering in "thousandth" as the scaling factor (Note that you will have to type this as it does not appear in the pull down menu).
