• 259 views | 2 messages Discussion: LEAP
    Topic: new version Subscribe | Previous | Next
  • Enas Mostafa 3/8/2021
    Hello there,
    When I updated leap to version: 2020.1.0.24 (64-Bit), it doesn't run and it shows me this message. The same areas used to run perfectly before I updated I was using versions 2020.1.0.19. How can I fix this please?
  • Charlie Heaps 4/3/2021
    That is not an error message - it is a warning to you. LEAP is alerting you that your data is likely inconsistently entered. I added this warning in a recent version of LEAP because I noticed that a lot of users were not properly defining their data.
    You can choose to ignore this by checking the box marked "Don't show this message again" and then clicking "No" to continue your calculations.
    But my suggestion is to investigate your data more carefully!
