• 202 views | 2 messages Discussion: LEAP
    Topic: Freeonia Template & Overview Example Subscribe | Previous | Next
  • Iwan Gunawan 3/11/2021
    Hai all
    First running LEAP, i have template for Freedonia Template. than i try to run Overviews Example tamplate...after that i can't change back to freedonia template...i tried to unistalled and back installed but still same tamplate for Overviews Tamplate...also i have tried to install via menu Area, than choose install from file, choose the C program files, but can't find anything to change back to freedonia template
    current template
  • Valentine Wambui 4/6/2021
    Hey Iwan,
    Can you see the Freedonia folder under Documents\Leap Areas which is where all the areas are stored? Also confirm which folder your areas are stored from settings/folders.
    If you can find the Freedonia folder, copy it to the active folder that Leap is storing the areas and this will enable you to open it.
    Hope this helps.
    Valentine
