• 351 views | 2 messages Discussion: LEAP
    Topic: Error Running IBC Subscribe | Previous | Next
  • Felipe Rojas 3/25/2021
    Dear Leap community,
    I am trying to use IBC for the national data of my country, Colombia, I have created a brand new area in LEAP to made this process, all the data has been updated but when I tried to run IBC I am seeing this messages.
    1. Leap area "" is not properly set up to use IBC, but I set up the scope and scale parameters properly.
    2. I tried to run IBC on my data set and in the asiana data set, but there is a new error message popping up " Error in scricpt IBCBeforeCalp at line 418"
    Before the last update, when I tried to use IBC I did not get this messages.
    Thanks for your help,
    Felipe.
  • Charlie Heaps 4/1/2021
    You cannot run those IBC-specific scripts directly from the Advanced: Edit Scripts menu. They are called internally by LEAP, when using IBC (and should not be edited).
    There are various requirements to get a data set working with IBC. Please start by reading this page: https://leap.sei.org/default.asp?action=IBC
    There is also a menu option Advanced: Check for IBC Compliance that can check for and add in the specific branches needed for a LEAP model to work with IBC.
