• 1074 views | 8 messages Discussion: LEAP
    Topic: Issue Loading GREAT DEMO data set for China Subscribe | Previous | Next
  • Jinguang Yang 5/6/2021
    Dear Developer,
    I am trying to use a open-source model called GREAT to study the energy consumption behavior in China. This framework is built on the LEAP framework with specialization on China.
    However, when I am trying to open the .leap file. It always ends up with a ERangeError, and I have to close the LEAP. I have attached the .leap file. Is there anyway I could solve it?
    Any help would be appreciated~
    Jinguang
    Attachments:  GREAT Demo L2012.leap [4]
  • Charlie Heaps 5/8/2021
    Hi Yang - I’ll take a look at this now but Range errors are most likely a bug. Will get back to you shortly.
    The data set was quite an old format (for LEAP2012) but it actually loaded fine for me into LEAP 2020.1.32. Maybe you have an earlier version of LEAP? In any case, here is a new version fully updated for LEAP2020. I also removed some older duplicate files so it is now much smaller (1.6 MB vs 8 MB).
    Attachments:  GREAT DEMO L2020.leap [7]
  • Jinguang Yang 5/10/2021
    Thank you very much Dr. Heaps.
    The model works perfectly now. I really appreciate it!
    Jinguang
  • Di Wu 12/20/2021
    您好!看到您的帖子,得知您正在使用GREAT。求教一下,GREAT从哪里下载,劳伦斯伯克利国家实验室官网GREAT下载按钮点击后总显示查找不到网页,不知道什么原因。此模型框架能否不吝分享,以供学习研究。感谢!!!
  • Di Wu 12/20/2021
    I am using the latest version of Leap (2020.1.0.46) and have the same Issue as "Issue Loading GREAT DEMO data set for China". It needs your modified GREAT Demo L2012.leap”。
    Di WU
  • Charlie Heaps 2/7/2022
    Apologies for the problems. I've fixed the web site so the above links now work. I've also created a newer version of the GREAT Demo data set that is updated for LEAP 2020.1.56. Attached here and I've also made it available directly in LEAP via the Area: Install: Install from Internet menu option.
    Attachments:  GREAT Demo.leap [5]
  • Di Wu 2/7/2022
    The best,
    Wu Di
