Dear LEAP-team,
after updating to LEAP 2020.1.0.32 and NEMO v1.6, the results for the area that I am working on have changed.
I am using LEAP for capacity expansion analysis in the power sector.
After analysing the differences, I found out that renewable processes (with the main cost parameter being capital costs) do get built less than before. Do you think that this could be caused by changes made in NEMO regarding interest rates of technologies and the annualization of capital costs? And if yes, is this a desired outcome?
(For clarification: Interest rates are not differentiated, all are set to discount rate)
To verify that the changes in results are caused by the update, I also reverted my area to earlier versions for which I have results documented. Those results are also different using the latest LEAP and NEMO versions.
But if you could share an installer for the previous versions with me, I could also compare the results directly.
I hope that you can understand my concern and request. Of course, I would be happy to provide you with more information if needed.
Thanks a lot in advance and kind regards,
Marek Fritz
Edit: I found installers for LEAP 2020.1.0.30 and NEMO v1.4 on my PC. Changes in results are definitely caused by the update. Would be really nice if you could give an explanation for this behaviour!
