686 views | 5 messages
Window scripting error
Innocent Nkurikiyimfura 5/26/2021
How can I solve this kind of error while running LEAP
Liya Cai 5/27/2021
Hi Dr.
Nkurikiyimfura
You could check whether there is a procedure named as Wscript.exe or Cscript.exe in command line. The above error occurs if the procedure Windows Scripting Host misses.
Sincerely,
Inna Kim 6/2/2021
what command line are you referring to? I have the same problem
Inna Kim 6/28/2021
Hi
Did you get your problem resolved? Having the same issue
Charlie Heaps 6/29/2021
Please see this thread:
https://leap.sei.org/default.asp?action=thread&tid=6073&fid=22
