• 299 views | 2 messages Discussion: LEAP
    Topic: Power Generation Double accounting Issue Subscribe | Previous | Next
  • Amanda Ngwenya 6/11/2021
    Good day support team
    I have a question with respect to the power generation showing in my result. Result view> Transformation>Power generation.
    My exogenous capacity  for 2010 base year is entered as 985 for thermal and 1180 for hydro power. However, in the results Power Generation view, LEAP is translating this into 54,1 thousand MW (16.8 thermal, 37 hydro and 0,3 coming from solar).
    My assumption is that the algorithm here takes the product of sum exogenous capacity and stipulated % of peak (from my system load -% peak yearly shape) to determine what to generate in each time slice?
    If this is the case, my time slices are split into  24 hours a day for wet and dry season.
    I have the same peak shape for each season. However, what seems is to be happening is that the model adds the wet season generation and dry season generation to decide yearly generation which then becomes a double accounting exercise  because its taking each season as occurring through out the whole year (2 seasons x 24hours x 365days, meaning two sets of 8760 hours) yet in actual fact they occur for certain periods within the year (a few months not the whole year).
    How do I  solve this issue? such that the model generates power required annually correctly - would it be correct to the leave one season as zero's? Please advise
    Amanda
  • Utsavshree Rajbhandari 6/19/2021
    Dear Amanda,
    Your question got me interested, but the information was not sufficient enough to actually know what it was.
    However, I tried to model it in Freedonia with hypothetical yearly shape data.
    Comparing my and your results, i felt that you might have been looking at the wrong result.
    The capacities installed are as shown here.
    but for power generation result , if you choose year in horizontal axis, the result is this. where it shows 18 thousand MW for 1000 MW coal plant.
    and i found that it is nothing but sum of power dispatched in the year, which can see if you choose Time slices in horizontal axis
    Please let me also know if it was the problem.
    If not, please do share more details, if possible.
    Utsav
